Best Fit curve to points where is this tool?
V5,
I have a stretched egg shape (lengthways) object and need to get a curve best fitting to the shape. start and end tangent .
rhs needs some trial to get curve at ‘cliff edge’ to best fit. Its obvious ish where the end will be.
If I plot points along its edge then call command BestFitCurveToPoints that should do it, but there is no command I can see.
Rhino V5
Also why has ControlPointCurve not an ability to startTangent and EndTangent ?
Is there a best fit to clicks curve, so as I click my way along it best fits a curve , so some clicks might be outside the final curve and some inside.
A curve smoothing out the slightly erratic click points. A bit like the BestFitCurveToPoints I ask about. Just without the initial points.
Steve
The tangent direction for a control point curve is determined by the end two control points.
So you can use Ortho to constrain the tangent direction to horizontal or vertical.
You might make a curve that looks soomething like this:
You can use Scale to edit the shape of the curve without changing the tangent direction at the ends.
