For now I’m satisfied with this little script that isolates into set selected curves. Essentially it inverts selection and executes -hide <setname>
And a complimentary Show.py that also shows named sets as options and if no name supplied restores all named sets only, leaving all other hidden objects hidden.
Isolate.py (2.1 KB)
Show.py (8.6 KB)
Isolate.py
Isolate.py
Version: 26.7.22.1837
Isolate selected objects by hiding all other visible normal objects.
The named set, when supplied, is assigned to the objects hidden by isolation.
Alias/button macro:
!_-RunPythonScript (import rhinoscriptsyntax as rs; g={}; execfile(rs.FindFile("Isolate.py"), g); g["isolate"]())
import Rhino
import Rhino.Input as ri
import Rhino.Input.Custom as ric
VERSION = "26.7.22.1837"
_SET_PROMPT = "Name of object set to isolate. Press Enter to isolate with no named set."
def _get_set_name():
getter = ric.GetString()
getter.SetCommandPrompt(_SET_PROMPT)
getter.AcceptNothing(True)
result = getter.Get()
if result == ri.GetResult.Nothing:
return ""
if result == ri.GetResult.String:
return (getter.StringResult() or "").strip()
return None
def isolate():
isolate_ids = rs.SelectedObjects(include_lights=False, include_grips=False) or []
if not isolate_ids:
isolate_ids = rs.GetObjects(
"Select objects to isolate",
group=True,
preselect=True,
select=True,
) or []
if not isolate_ids:
return
isolate_ids = list(isolate_ids)
isolate_set = set(isolate_ids)
to_hide = [
object_id
for object_id in (rs.NormalObjects() or [])
if object_id not in isolate_set
if not to_hide:
Rhino.RhinoApp.WriteLine("Isolate: nothing to hide.")
return
set_name = _get_set_name()
if set_name is None:
return
safe_name = set_name.replace('"', "'")
command = '_-Hide "{}"'.format(safe_name) if safe_name else "_-Hide _Enter"
redraw = rs.EnableRedraw(False)
try:
rs.UnselectAllObjects()
rs.SelectObjects(to_hide)
success = rs.Command(command, False)
finally:
rs.SelectObjects(isolate_ids)
rs.EnableRedraw(redraw)
if not success:
Rhino.RhinoApp.WriteLine("Isolate: Rhino Hide command failed.")
if __name__ == "__main__":
isolate()
Show.py
show.py
Version: 26.7.24.1119
Show objects from one named Rhino hide set, or press Enter to show every
named set. Ordinary hidden objects remain hidden.
Alias/button macro:
!_-RunPythonScript (import rhinoscriptsyntax as rs; g={}; execfile(rs.FindFile("show.py"), g); g["show"]())
import clr
import Rhino
import scriptcontext as sc
from System import Array, IntPtr, Object
from System.Reflection import BindingFlags
from Rhino.Runtime.InteropWrappers import StringHolder
VERSION = "26.7.24.1119"
_PROMPT = "Name of object set to show. Press Enter to show all named sets."
_MAX_OPTIONS = 20
def _find_native_methods():
try:
object_type = clr.GetClrType(Rhino.DocObjects.RhinoObject)
pointer = object_type.GetMethod(
"ConstPointer",
BindingFlags.Instance | BindingFlags.NonPublic,
assembly = clr.GetClrType(Rhino.RhinoApp).Assembly
unsafe_type = assembly.GetType("UnsafeNativeMethods", False)
if unsafe_type is None:
return None, None, None
flags = BindingFlags.Static | BindingFlags.NonPublic
get_name = unsafe_type.GetMethod(
"CRhinoObject_AttachHideGetName",
flags,
remove_name = unsafe_type.GetMethod(
"CRhinoObject_RemoveHideName",
flags,
return pointer, get_name, remove_name
except Exception:
_POINTER_METHOD, _GET_NAME_METHOD, _REMOVE_NAME_METHOD = _find_native_methods()
def _arguments(*values):
return Array[Object](list(values))
def _pointer(rhino_object):
if _POINTER_METHOD is None:
return IntPtr.Zero
try:
value = _POINTER_METHOD.Invoke(rhino_object, None)
return value if value is not None else IntPtr.Zero
except Exception:
return IntPtr.Zero
def _hide_set_name(rhino_object):
pointer = _pointer(rhino_object)
if pointer == IntPtr.Zero or _GET_NAME_METHOD is None:
return None
holder = StringHolder()
try:
found = _GET_NAME_METHOD.Invoke(
None,
_arguments(pointer, holder.NonConstPointer()),
if not found:
return None
name = holder.ToString() or ""
return name if name else None
except Exception:
return None
finally:
holder.Dispose()
def _remove_hide_set_name(rhino_object):
if pointer == IntPtr.Zero or _REMOVE_NAME_METHOD is None:
return False
try:
return bool(_REMOVE_NAME_METHOD.Invoke(None, _arguments(pointer)))
except Exception:
return False
def _native_access_available():
return all(
method is not None
for method in (_POINTER_METHOD, _GET_NAME_METHOD, _REMOVE_NAME_METHOD)
def _is_internal_name(name):
return len(name) >= 4 and name.startswith("$$") and name.endswith("$$")
def _is_hidden(rhino_object):
return bool(
rhino_object.IsHidden
or rhino_object.Attributes.Mode == Rhino.DocObjects.ObjectMode.Hidden
def _named_sets(document):
settings = Rhino.DocObjects.ObjectEnumeratorSettings()
settings.NormalObjects = True
settings.LockedObjects = False
settings.HiddenObjects = True
settings.IdefObjects = False
settings.DeletedObjects = False
settings.ActiveObjects = True
settings.ReferenceObjects = False
settings.IncludeLights = True
settings.IncludeGrips = False
settings.IncludePhantoms = False
settings.VisibleFilter = False
sets = {}
for rhino_object in document.Objects.GetObjectList(settings):
if not _is_hidden(rhino_object):
continue
name = _hide_set_name(rhino_object)
if not name or _is_internal_name(name):
continue
key = name.lower()
hide_set = sets.get(key)
if hide_set is None:
hide_set = {
"name": name,
"order": int(rhino_object.RuntimeSerialNumber),
"ids": [],
sets[key] = hide_set
hide_set["order"] = max(
hide_set["order"],
hide_set["ids"].append(rhino_object.Id)
return sorted(
sets.values(),
key=lambda item: (item["order"], item["name"].lower()),
def _normalize(value):
value = (value or "").strip()
if len(value) >= 2 and (
(value[0] == '"' and value[-1] == '"')
or (value[0] == "'" and value[-1] == "'")
return value[1:-1].strip()
return value
def _is_ascii_letter(value):
return ("A" <= value <= "Z") or ("a" <= value <= "z")
def _option_name(set_name, position, used):
base = "".join(
character
for character in set_name
if _is_ascii_letter(character) or ("0" <= character <= "9")
if not base or not _is_ascii_letter(base[0]):
base = "Set{}".format(position)
name = base
suffix = 2
while name.lower() in used:
name = "{}{}".format(base, suffix)
suffix += 1
used.add(name.lower())
return name
def _get_set_name(named_sets):
try:
getter.SetCommandPrompt(_PROMPT)
getter.EnableTransparentCommands(True)
options = {}
used = set()
for position, hide_set in enumerate(named_sets[:_MAX_OPTIONS], 1):
set_name = hide_set["name"]
option_name = _option_name(set_name, position, used)
option_index = (
getter.AddOption(option_name)
if option_name == set_name
else getter.AddOption(option_name, set_name)
if option_index > 0:
options[option_index] = set_name
if getter.CommandResult() != Rhino.Commands.Result.Success:
return None
return ""
return _normalize(getter.StringResult())
if result == ri.GetResult.Option:
option = getter.Option()
return options.get(option.Index) if option is not None else None
return None
finally:
getter.Dispose()
def _capture_selection(document):
if Rhino.RhinoApp.InCommand <= 1:
return None
snapshot = []
for rhino_object in document.Objects.GetSelectedObjects(True, True):
state = rhino_object.IsSelected(True)
if state:
snapshot.append(
rhino_object,
state in (1, 2),
state == 2,
list(rhino_object.GetSelectedSubObjects() or []),
return snapshot
def _restore_selection(document, snapshot):
if snapshot is None:
return
document.Objects.UnselectAll()
for rhino_object, whole_object, persistent, sub_objects in snapshot:
if whole_object:
rhino_object.Select(True, True, persistent, True, True, True)
for component_index in sub_objects:
rhino_object.SelectSubObject(component_index, True, True, False)
document.Views.Redraw()
def _show(document):
if not _native_access_available():
Rhino.RhinoApp.WriteLine("Named hide-set access is unavailable.")
return
named_sets = _named_sets(document)
requested_name = _get_set_name(named_sets)
if requested_name is None:
return
show_all = not requested_name
object_ids = [
object_id
for hide_set in named_sets
if show_all or hide_set["name"].lower() == requested_name.lower()
for object_id in hide_set["ids"]
if not object_ids:
description = (
"any named set" if show_all else "set {}".format(requested_name)
"No hidden objects in {}.".format(description)
return
shown = 0
for object_id in object_ids:
if not document.Objects.Show(object_id, False):
continue
shown += 1
rhino_object = document.Objects.FindId(object_id)
if rhino_object is not None:
Rhino.RhinoApp.WriteLine("Shown {} object(s).".format(shown))
def show():
document = sc.doc
selection = _capture_selection(document)
try:
_show(document)
finally:
_restore_selection(document, selection)
show()
