Hello Forum, looking for advice on best approach to create 5mm thickness inlays into the shaped object. End goal is natural stone, with inlayed brass, both on the horizontal surfaces and the verticals. What would you suggest the best workflow is to achieve this? tia
Hi Kyle, yep this works a treat. I wouldnāt have even thought to use PushPull for this scenario, in fact itās not something I use a lot, but this has to be the best case Iāve seen to use PushPull, I owe you a beer, cheers
(edit, btw end goal is for CNC machining, transfering .3dm file to EasyStone CAM softwares, so important for good modelling, a nice simple render is a nice addition though)
