Bending a rectangle like a page in a book
Fairly simple question. I have a rectangle made from polylines. I want to take one vertices and move it any direction but keep the other vertices fixed, however, instead of those connected lines remaining straight, I would like them to bend like a page in a book. I would also like to control the radius of these lines. SoftEditCrv works on crvs for me but not straight lines.
Any help would be much appreciated.
Thanks
Hello - if the object is a rectangle as a curve, ChangeDegree to 3 and InsertKnot > Automatic a few times to get the number of control points you need. If the object is a plane (surface), then Rebuild to degree 3 by 3 and maybe 10 points each way.
Great - Worked exactly as wanted!
Thanks!
