Bend or fold?
Hello rhinos,
Im trying to bend or fold a sheet material with thickness of 12mm with a groove in it.
Below is a folder result and sheet material with a groove. What would be the best approach? I had no luck using bend command. I did the result image by splitting the sheet in 2 parts and rotating, but that would be a pain for me. Is there any way?
What are you trying to achieve? You don’t really make this stuff by bending flat models, you just model it as you want the result then maybe try to unfold it.
One of several ways:
  1. Make a polyline with two segments of the desired lengths and angle.
  2. Offset the polyline by 12mm with cap=flat and trim=yes options.
  3. Extrude the resulting surface by the desired length of the sheet.
HTH
Jeremy
Im working with flat sheet material with dimensions of 1200x3000mm and thickness of 12mm. We are cutting grooves on a CNC based on client curves. For design purposes i want to be able to draw a curve on a sheet after, i will boolean the groove and want to use the bend/fold command to experiment with different shapes and forms.
