Beams are not connected to each other in Karamba
I have a problem with the connection of beam elements. I have already done a intersection of the lines and still the beams are not connected to each other. What might be the problem?
Best,
Tarik
beams_not_connected.gh (30.8 KB)
Hi, you should remove the point input, the points are only needed for controlling the order or if you want zero length elements.
Hi Matthew,
thank you for your help.
For people dealing with similiar problems: Another problem that i found in another more complex system is, that my elements had different branch structures. They need to be simplified in order to share the same branch structure. This can also lead to connection problems.
