I can’t seem to figure out the Beam|Id input for the beam loads component. I need to input multiple Id numbers per load. I followed the example in the manual. For example, I need to apply the load to id’s 159, 160, 161. But when I input it like “&159|160|161” it also applies the load to beams 15936, 15935, etc. It seems to be wildcard matching. Is there a way to input a list of ids and let it apply that load to exactly those ids like in previous Karamba versions?
Is there no solution for this?
Dear @e.estrado,
sorry, I did not see your post right away. I will take a look at the issue asap.
– Clemens
Dear @e.estrado,
try “&159$|160$|161$” in your regular expression using “$” to match the end of the string.
– Clemens
I had to format it like this “&^159$|^160$|^161$” to match the beginning and end of the string. It works now. Thanks @cp1
