How to get beam cut angles, start and end cut, into a table report? I normally have the cut plane set to “Auto”. I want to create a list with beam cut length, start- end- cut angle, qty name etc. Have everything sorted except cut angles.
Thanks,
Thanks,
Hi @Magnus_Strand It’s not possible to display the beam cut planes as angles in a table report.
It should be possible to list the Beam Start/End cut planes property as they appear in the object properties (“Auto”, “Vertical”, “Horizontal”, and “Perpendicular”). Would that work for you?
For showing the End cut plane, you would select this parameter in the Table style dialog > Source tab:
Hi @fsalla
I would have preferred to have the values as below listed in a report; cut length and start- and end cut angle. I have found the beam start/end cut plane property, but only able to get the “Auto”, “Vertical”…)
Got it! I add your vote for this feature in future versions. I’ll keep you posted.
