How do I evenly distribute a small spheres on a curve (beads on a string) so that spheres are
evenly spaced right next to each other. Can I also do that on multiple curves at the same time?
You may give it a try with ArrayCrv
Hi @jessesn,
I don’t know whether ‘Box rotation spacing’ is intended to cater for this, but at the moment there doesn’t seem to be a way to stop objects on a tight curve from overlapping, as here:
Regards
Jeremy
Thank you for your report, and the feature request is on the list as RH-95070
