Batch plot from Grasshopper to pdf
Greetings Forum.
I cant figure out how to make a batch plot to a single xx.pdf file from grasshopper.
In the normal plot window it works like a charm.
But in grasshopper with the “GH” settings i get this result. single files..
Let me hear if you got a solution.
Soren.
The symptom — manual Print gives one PDF, Grasshopper-driven printing gives one file per sheet — almost always comes down to how many times -Print gets called, not a Rhino limitation. The manual dialog lets you multi-select layouts and issues one print job across all of them; a GH-driven loop that calls print once per layout, even with identical settings, produces one job and therefore one file per call, because each call to the print pipeline is its own file by definition.
Two ways out, and they solve slightly different problems:
1. One call instead of a loop. If the automation currently iterates layouts and issues -Print per layout, restructure it to pass the full set of layouts you want combined into a single -Print invocation (SelectedViews covering all of them, one PrintFile destination). That reproduces exactly what the manual dialog does when you multi-select layouts — the combining isn’t a manual-mode-only feature, it’s a property of doing it in one job rather than N jobs. This is the right fix if every sheet shares the same page size and print settings.
2. Merge after the fact, if per-layout calls have to stay separate. If the GH pipeline genuinely needs per-layout control (different scale, different settings per sheet, layouts generated dynamically), keep the N individual PDFs from the loop and add one merge step right after: a short Python step using pypdf (PdfWriter().append(path) for each file in sheet order, then write()) turns N files into one. This decouples “one file per print job” from “one file for the deliverable” entirely, and it gives you full control over sheet order and naming that a black-box combine setting wouldn’t — worth doing even if fix 1 also works, since dynamic pipelines tend to need it eventually anyway.
One thing worth checking before either fix: are all the layouts actually the same page size and orientation? Some combine paths will silently misplace or crop content when sheets differ, which reads as a “broken” merge rather than a settings issue, and it’s a five-minute check now versus a confusing report later.
Which of the two is worth doing depends on one detail you’d know and I wouldn’t from the screenshots: is the current pipeline really one -Print call per layout, or already one call across all of them that’s still splitting? That decides whether this is a call-structure fix or a genuine plotting bug.
