Good afternoon,
Is there any tutorial or document that explains the BarkBeetle process? I found the file a bit complicated, and I need to generate some CNC milling.
Thank you!
Good afternoon,
Thank you!
Any more info? What is Barkbeetle? What file? What are you trying to do?
I want to simulate the CNC milling process by using Grasshopper. I couldn’t find a plugin for that, but someone suggested using BarkBeetle , which is a Grasshopper definition for CNC milling. The definition is complicated, and I need a tutorial or a document to understand it. Do you have any suggestions?
@siemen is involved in this project as far as I know. It might help if you could post a couple of specific questions, in case there is no documentation, beyond the GitHub page.
Thank you!
Hi @eiman.graiz,
I realize the definition is not super intuitive, but can you try out these steps from the github documentation and let me know where you get stuck so I can try to update the page when I have the time?
To use the streaming function of the file, you need to first specify your streaming destination. Cloud storage connected to the pc running your cnc-machine can be a huge time safer here. All changes will then be automatically streamed to the folder of your machine.
Now every time you make a job, this file will automatically update, ready for you to run the job.
How I can create a custom post-processor for BarkBeetle?
