Ball corner - Folowing the thirtysixverts primary surfacing tutorials
Hello everyone!
Has match surf changed its g2 behavour lately? it often seems match surf in 8 creates tangency over centerlines (as it should be) when i hit average surface and G2 in the macht srf command.
But what i seem to remember form before is, that this would give you the flat spot.
As if the match surf command now says “I get it, you want curvature but I wont give 2 row allignment because this seems to be over a symetri line and therefore I wil insted do a 1 row alignment from the edge.”
I am currently on a project to go thru the primary surfacing tutorials of thirtysixverts, methodically.
Im at the ball corner, and it seems like the curve blends that was critiqued series from 2020 may have improved, or their default curvature graph whent form a “two hump dromedar” to a “one hump dromedary” (i’m referring to what is said at 15:30 min out in episode 11) Now i havent gotten to episode 11 yet this time around, so we’ll see, but now at episode 9, it seems like my curve blends gave the graph that Sky was advocating for.
I struggled however to get the kind of result as fast and easy as he did. i had to “reverse engineer” my way to the result, it should be said that i got to the starting point by changing the degree of degree 3 fillets, to degree 5 and then matching them to the sides by curvature.
At first i tended to get results like this with multiple matches, g2 and match target isocurve dir,
To get close to the result in the episode i had to manually arrange the points.
Here is the result so far:
Tangency is not all the way below 0.1deg. You can allso se some scratches in the zebra there.
But the point is - you can see how I used surfaces and lines to line up the points the way i wanted manually, in order to get my result.
I wonder why I had to do that, and it dint work out as smoothly when i only used match command and basically followed the tutorial.(Episode 10 https://www.youtube.com/watch?v=VjVE9678Ltg)
By a bit of tweaking of 2nd row and for instance tweaking these two points in the blue arrow direction(with reduced drag strenght) I was able the tangency target, the glitch in zebra however is still there
Very difficult to understand what you really mean. Maybe you can supply two screenshots? One with what you expect. One with what you get.
Here’s a straightforward way to do it.
NURBS G2 corner fillet principle.3dm (468.5 KB)
This happens to me pretty regularly and it’s a bug in the “Match surface” tool. Another bug is the inability to match the natural flow of the target surface when using G2. Instead, Rhino overreacts by trying to straighten the 3rd row of control points.
The VSR plug-in for Rhino 5 had a much better implementation of “Match surface” that worked just like the tool in Alias.
Note that sometimes Rhino will change the weight of certain control points after you apply “Change degree” or “Rebuild”. It’s a good practice to check the cp weight just in case (and set it to 1 to all control points if it was modified).
Rhino 9 BETA is able to render the control points with a modified weight as diamonds (squares rotated by 45 degrees).
I just tried the new static “Zebra” analysis on your 3d model. Seems like some areas could be further improved.
The main issue with the multi-span surfaces is that they tend to generate sudden change of curvature in the areas where you modify the position of the control points manually. This may not be a problem if the multi-span surface is matched with “Match surface” without any further manual editing.
In case that I will know that I want to do some extra control point “massaging”, I prefer to split the multi-span surfaces into multiple single-span ones. This usually helps a lot in highly curved areas.
That’s not the point. The point is the correct approach. You can always noodle CPs if you want.
I meant the matching of the secondary surfaces to the target edges of the primary surfaces. Unlike Alias, Rhino is notorious with the inability to properly match surfaces with the same properties (same degree and same number of control points). This is why the Rhino users are forced to either use the “Refine match” option of the “Match surface” tool (adding more spans), or increase the degree, or manually insert knots (adding more spans), or split the surface to be matched into two or more smaller pieces.
It’s somewhat possible to manually match the adjacent surfaces in a similar fashion like you do in Alias, and still keep them degree 5 with 6 control points in either direction, but it’s very time consuming. The automatic solution with “Match surface” is flawed. This is where the increased degree helps a lot if one relies on the “Match surface” tool instead of doing the matching manually.
Here is a slightly improved version of your model where I converted the multi-span surfaces to Bezier ones, then I increased the degree by 1 on the upper corner surfaces. These operations are not needed in Alias where the program is capable of properly matching the adjacent surfaces, but in Rhino we have to deal with the shortcomings of the “Match surface” tool and use various workarounds to compensate the lack of proper matching.
NURBS G2 corner fillet principle - Bobi.3dm (8.0 MB)
I agree.
MEGA IMPORTANT!!!
Make sure that the weight of all control points is set to 1, otherwise some tools in Rhino will behave in a crazy way! Certain commands in Rhino tend to modify the control point weight without a warning, leaving your surfaces prone to potential geometrical distortion whose only fix is to reset the weight back to 1 and match every involved surface again. There are two main ways to reduce any potential bug like this:
Tip 1: Check if the control point weight of your existing surfaces and curves are all set to the default value of 1! If not, fix that by selecting the control points and running the ! _Weight command. If you use Rhino 8 or older, it’s a good practice to check the control point weight every time after you use “Rebuild” or “Change degree” on some surface.
Tip 2. Rhino 9 has a dedicated setting for rendering the weighted control points in a different way. It could be enabled individually for each display mode and you can find it here:
Rhino options > View > Display modes > (expand the preferred display mode) > Objects > Weighted control point style > Set it to "Diamond with white center".
That will easily tell you if the weight of some control points is modified accidentally.
Absolutely.
Indeed, this is not good, particularly bound to throwing off novices.
Thats fair to point out Lagom. (no pun intended)
Here is are 3 pictures
Yeah, wonky CPs - that’s the error in the MatchSrf tool @Rhino_Bulgaria mentioned higher up. You need to do some manual CP noodling with the MoveUVN tool, but that’s quick to do.
Thanx! yes. the pint wait is kind of a big deal. I thought Id never mess with weight my self, because id suspect id loose track of which points i had changed or not (they should be marked with color coding or something so you can know which point is not at default weight)
Kind of a bummer that this happens un notified.
This is before matching, so it happens at EdgeSrf command then i guess.
Yes I guess I can do that.
I have a trial version of the Cyberstrac plugin, right now. But the objective now was to learn stock Rhino better, that’s why I go thru those thirtysixverts episodes.
(I don’t want to become addicted to a plugin i didn’t plan to pay for just yet)
I looked at your file.
A neat idea to have it be 2surfaces, so it could be like tangent over centerline or close to that.
Neat trick!
I also reset the Point weight… it made a world of difference.
I have to say its a big deal, how can people learn to surface if the rules (point weight) is shifting.
Yeah…
I’ll just post my resulting corner.
Ball corner ala Thirtysixverts PrimarySRF Episode_10.3dm (16.2 MB)
