Baking Revit Components to Rhino as 3d Geometry
I want to bake MEP elements from Revit linked models into Rhino as a workable geometry for a visualization exercise. Ultimately, I want to create an exploded axo/infographic and want to leverage Rhino tools (Make2d and Bool operations) and importing the specific elements/categories from each of my linked and host model seems like the best first step. Attached is my start point, its is throwing the error “Data conversion failed from Revit Component to Brep” What is a better method to achieve baking geometry to Rhino for more complex families that have both curves and geometry in them?
Example_01.gh (5.1 KB)
Hi Basualdo_Armando,
What version of Rhino, Revit & RiR are you using?
Can you provide an example of what’s not working for you?
Thanks for the quick response, I was trying to use the Brep and Curve nodes and not the Graphical Elements Node.
