humppi
(Harri Humppi)
March 18, 2026, 7:51am
1
The Graphical Element component can bake elements from the current file, but it cannot bake objects linked from other Revit files. Is there a workaround for this?
Japhy
(Japhy)
March 18, 2026, 3:33pm
2
Hi Harri,
The workflow you describe should suffice in most cases
humppi
(Harri Humppi)
March 26, 2026, 7:45am
3
Hi Japhy!
For some reason only layers are baked for the linked elements. I don’t get any objects. Baking works fine if the same elements are not linked.
Japhy
(Japhy)
March 26, 2026, 11:30am
4
Good day Harri,
Can you provide some additional details about the type of object that you’re baking? That could be a big factor, for instance if you were baking curtain wall.
humppi
(Harri Humppi)
March 27, 2026, 8:29pm
5
Hi Japhy,
It seems this problem applies to all object types.
For example, I’m trying to bake walls from a linked Revit file; even though the preview is visible, no objects are actually appearing in Rhino.
Japhy
(Japhy)
March 27, 2026, 8:39pm
6
what happens if you do a cntl+A in the Rhino file? anything selected?
are their any blocks in the block manager?
humppi
(Harri Humppi)
March 30, 2026, 10:09am
7
Nothing is selected if I do Ctrl + A.
BlockManager seems to show one of the walls that can be inserted to Rhino:
Japhy
(Japhy)
March 30, 2026, 1:25pm
8
Thanks Harri,
So it’s not a file units issue.
Can you package up a small example? Revit file, gh file, Rhino file? Thanks
4. Isolating the issue and posting files
Revit projects are rarely small & the issues are rarely simple. Its understandable that support files aren’t always readily uploadable, for size or for privacy concerns.
That said, here are some recommendations:
Isolating the question to a new Revit file with the Revit Version in the File Name, then purge the Revit file several times to reduce size.
List your GH plugins needed to review the question, if possible remove all gh plugin components no…
humppi
(Harri Humppi)
March 30, 2026, 3:38pm
9
Thanks Japhy,
Here is the previous example packed.
Test.zip (11.7 MB)
Japhy
(Japhy)
March 30, 2026, 6:45pm
10
thanks, seeing this as well.
At the moment you can get the Element Geometry Bake using Content Cache (or similar)
opened 06:44PM - 30 Mar 26 UTC
user-bug
Reported and tested in Revit 2023, Rhino 8
https://discourse.mcneel.com/t/baki… ng-linked-revit-elements/217112/9
Linked objects are not baked via Right click bake. Content Cache gives an error on linked elements
<img width="1031" height="411" alt="Image" src="https://github.com/user-attachments/assets/d429c7f0-98b6-4b5e-923d-f65a02f50fda" />
