Baking geometry as separate instances of the same block
Grasshopper community,
I’m working with this script to bake trees as separate blocks. The issue with the script is that it creates one block containing 3 objects but what I need is to create 3 blocks with the same name. In other words 3 instances of the same block. I’m not really an expert using Grasshopper so I would appreciate if anyone can shed some light.
Thanks,
Hi Harold, You will need to match your trees. First right click your block name panel and make it multiline, so you can add 2 more names. Then right click on the BN and graft, same with the G in that component.
Thanks Japhy. That was exactly what I needed.
