ShynnSup
(Shynn Sup)
September 14, 2018, 7:31pm
#1
I wonder if this is possible now somehow, or if it will be possible in the future…
It would be incredibly useful to just right-click and “bake preview on”, baking every component that has its preview enabled.
Maybe generating a layer for each component, or grouping the geometry in each component. Or maybe just bake it as is…
Rickson
(Rickson)
September 14, 2018, 9:08pm
#2
By preview seems pretty limited, especially if you worked with Grafted information a lot.
here i constructed 10 points, on 10 layers, with 10 colors. Baked.
Then reverenced all the layers, culled the ones turned off, grouped them and baked.
If it was a bunch of different scripts that needed baking i would use the Bake All component, which bakes them all at once.
ShynnSup
(Shynn Sup)
September 14, 2018, 11:06pm
#3
Thanks for the example. I think that with some time you can set up a very good baking automation. I was hoping I could avoid this by just baking all components that have preview enabled at once.
Many times I find myself inputting all components that will be baked into a merge component to be able to bake them all at once. Not an ideal workaround.
Rickson
(Rickson)
September 15, 2018, 12:13am
#4
Metahopper has potential to do that i believe.
ShynnSup
(Shynn Sup)
October 13, 2018, 1:12am
#5
Found this thread where David shared a script that groups all geometry that has “preview enabled”
Maybe it is useful for someone else:
For completeness, this contains the same content of the C# script, also translated into Python.
collectgeo.gh (10.5 KB)
