This is a script where i have projected an image onto multiple surfaces. i want to bake what i see into the rhino port or i need some way where i can send multiple images that are projected onto the rectangles for 3d printing them. i have attached the (gh) script for reference -
I thought in that other thread it turned out you wanted a texture. Now you want it to be actual geometry?
Those just look like flat planes with a texture on. What exactly do you want to 3d print? Do you want multi material or must that shape be cut away or what?
That image doesn’t really help. Will look at files later…
As mentioned in your other thread, to bake your textured mesh into the rhino viewport, select the custom preview component and press INSERT on your keyboard, or right-click the component and select ‘bake’, then set your view to ‘rendered’.
