Bake curves with decorations (aka 'vectors')
I would like to bake vectors from Grasshopper. However, since Grasshopper doesn’t allow this, the two workarounds I can see are:
Option 1. Bake a curve. When this is done manually, there is the decoration option ‘ArrowAtEnd’. Once baked, the object is a curve and the visibility of the arrow can be cotrolled via the ‘Arrowhead’ command (not on menu).
But is there a way to apply a decoration using Rhino 8’s cache component, instead of manually baking it with the correct settings?
Option 2. Bake a leader without text. This is possible within Grasshopper, but working with leaders, instead of curves, potentially adds more complexity downstream.
Any thoughts on how to get decorations in Grasshopper, and if you think that is the best option?
Unfortunately right now Option 1 is not available through ‘Model Object’ and ‘Content Cache’.
Option 2, the leader could be a workaround, but the curve can only be a polyline or a degree 3 spline, and should be planar. On the other side you can customize the arrow size and shape.
A python script after the cache component will run whenever the cache is updated and can add the arrowhead to the model curve.
add_arrow.gh (11.4 KB)
That is great. Thank you.
