Hi, if possible I need your help since I cannot generate any volume in rhino using the grasshopper command “Bake”. I’ve made a building facade using grasshopper but when I’ve put it on the building I noticed that the hight and lenght was wrong so I deleted it on rhino and adjusted the dimensions on the algorithm but in the moment to conclude and bake the new facade I’ve encountred this problem. Below I’ve attached the document of grasshopper and also the pic of the old facade and the new one only made by lines. hope you can help me and thanks in advance
ALGORITMO FACCIATA 3 aperture.gh (30.7 KB)
Looks like you have your viewport set to wireframe
