Hi I’m encountering a number of problems with vray and badger, where previously things were working absolutely perfectly. I’m running the newest versions of vray and rhino 5
these are the issues:
-unable to save out 32 bit file types from a badger render job (a work around is to enable vfb history within the VFB and then save everything out from the resulting file)
-the ‘load vray options’ node doesn’t seem to work anymore, i have a work around using the badger ‘run command’ node and then running the vrayLoadSettings command but its not ideal.
-unable to specify custom resolution within the badger ‘render’ node
-render elements dont render out from badger
is anyone else experiencing these or similar issue?
