Splitting object1 with object2 will result in a bad object.
This I notice happens quite often. I attached the rhino file.
Hi - I can’t reproduce that here. Could you run SystemInfo
and post the result here?
BTW, do you know how many surfaces there are in that file?
Also, I’ve been told several times that Rhino is happiest when running on a tolerance in the range of 0.01 to 0.0001. You are running at 1.0.
Hi @wim, here’s the systeminfo.
in this file that i posted there are only those 2 surfaces. and i get the bad object in this file.
I’m trying to understand why in many cases the split works but in some others, like this one, it doesn’t.
and i’m always using this tolerance.
Rhino 6 SR19 2019-10-22 (Rhino 6, 6.19.19295.01001, Git hash:master @ 0af62045bd35259d4c2367dbf7f9ef94ded29299)
License type: Commercial, build 2019-10-22
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: AMS-WS309
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro P4000 (NVidia) Memory: 8GB, Driver date: 5-22-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 397.93
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-22-2018
Driver Version: 24.21.13.9793
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.19.19295.1001
C:\Users\b.chipara\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.19.19295.1001
C:\Program Files\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino.Plugin” 0.0.19316.1331
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.19.19295.1001
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
Hello - I see that here - but working at 1 unit tolerance, I don’t doubt that you see this quite often - see
https://wiki.mcneel.com/rhino/faqtolerances
Hi Bogdan,
That’s wrong, by the way. There are 3 surfaces.
On the one that probably shouldn’t be there, one of the edges is 0.136 millimeters.
