Rh5sr8
The attached file checks as good, but all meshing options just leave out one section of the manifold.
I’ve replaced/rebuilt it several times with ho joy.
Help? Yuyu Long-solvent dispensing manifold 3D.3dm (725.0 KB)
Rh5sr8
Hi Chris- your object is a little odd in that it has some zero-thickness locations- that seems to be where the mesh goes wonky and leaves gaps- is that what you are pointing out?
All meshes good but for one part.
I’ll try a ‘slight’ mod.
Thanks
Sorry
, forgot the image
Well, here is the single part of the model that just won’t mesh.
What do you suppose is the issue?
Chris
Won’tMesh.3dm (50.2 KB)
Hi Chris,
use _SrfSeam an relocate the seam tothe lowest point of the circle.
c.
Clement, that did it! I guess it was the cutout interfering with the seam.
Learned somethin’ new today.
Thanks.
Chris
Yeah… but I think it should still work without having to do this…
–Mitch
Hi Mitch,
yes, of course. I´ve just forgot to complain
Without moving the seam, it can be fixed using Split by Isocurve and snap at the opposite site at the lower corner of the V-shaped trim. This results in multiple meshable faces, though.
c.
