Hi…,
where to change the panel background color. Here is a picture of customers panels in gray, what he doesn’t like anymore.
Thanks
Michael
www.flexiCAD.com
Hi…,
Thanks
Michael
www.flexiCAD.com
Rhino options > Appearance > Colors > General > Window color 1
Hi Wim,
“Window color 1” changes here the toolbar color, not the panel color.
Perhaps I should be more precise, I am talking about this gray.
Other ideas, perhaps a registry setting?
Thanks
Michael
www.flexiCAD.com
I may be mistaken here, but the inactive tabs are in Rhino Window color 3; however the active tabs are the Windows native Menu bar color and can’t be changed without changing the system color scheme… Someone correct me if I’m wrong please…
–Mitch
I guess there are two types of active tabs then.
In this picture, the perspective viewport is active — General > Windows color 2
The right, front, top viewports are inactive — General > Windows color 3
I tried tweaking the OS system color scheme to get to the layer tab color but couldn’t find it.
There are several color settings exposed in Rhino 6 in the options > advanced meny but this one isn’t there either.
Yeah, the viewport tab colors are accessible… I think there may have been discussions/requests in the past for some of the other ones that are not. --Mitch
Hey there, I am the customer.
If I go to _Options / Appearance / Colors and Press [Reset defaults] (German: Standardwerte wiederherstellen), the colors switch back to the original default colors (see 2) until I close the options dialog with either “OK” or “Cancel”. After leaving the options dialog the screen is flickering some microseconds and the ugly dark gray is restored. (see 3).
Rhino 5 SR 12 64-bit 5.12.50810, Win7 Pro 64-bit
Problem solved, thanks to ProcessMonitor (from Sysinternals) and RegEdit.
I removed the following registry entry that was set to 13160660 = 0xC8D0D4 = 200,208,212 BRG = 212,208,200 RGB = the dark gray in my upper screen shot and everything is back to normal now:
HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\5.0x64\Scheme: Default\Options\UiPaintColors\tab_background
Hi Dirk,
thank you for your engagement and these details.
Have a nice weekend
Michael
www.flexiCAD.com
