Hi I’m new in grasshopper. The problem that I face is that the the green planks that you say see in the picture they are vertical to the curves but I need there back side to be tangent to the curves. Drive with flow surface but it didn’t work. Do you have any suggestions?
Thank you, I appreciate it.
It works well.
The only thing is that in some areas doesn’t smoothly follows the curve. Do you have something to suggest for that?
The only thing is that in some arias doesn’t smoothly follows the curve.
