Hi there,
I’m just trying to access an Azure table using the following NuGet assembly in a C# scripted component:
It looks like we can’t directly link this using the “manage Assemblies…” functionality, but I can unzip the *.nupkg file to get the dll and then link that. I then insert the following using line:
using Microsoft.Azure.Cosmos.Table;
So far so good. However, now I try to create a StorageCredentials object:
StorageCredentials creds = new StorageCredentials(accountName, accountKey);
and I get the following error:
Error (CS0012): The type ‘System.Object’ is defined in an assembly that is not referenced. You must add a reference to assembly ‘netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51’. (line 64)
A similar thing happens if I try to use the older Microsoft.WindowsAzure.Storage assembly, except I get a slightly different error:
Error (CS0012): The type ‘System.Object’ is defined in an assembly that is not referenced. You must add a reference to assembly ‘System.Runtime, Version=4.0.20.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’. (line 64)
Anyone have any ideas about this?
Has anyone had any luck querying an Azure database before?
Thank you,
Steven
