I am using AWS Lambda to deploy a multiple instances optimization algorithm in phython3.8. There I would need to import the rhino3dm (or rhino.compute) library, however if I run the code on Lambda, it gives me an error that AWS Lambda runs an older version of GLIBC. Is there any way to update the GLIBC or to install the rhino3dm libraries on AWS Lambda?
I have tried two approaches:
AWS Lambda Layers
I have installed the rhino3dm packages with pip (pip3 install rhino3dm -t ./)
I zipped the library and uploaded it into the AWS Lambda layer
I haven’t tried building the python rhino3dm library for Linux lately, but have a need for this in the upcoming weeks. I’ll try to make a build myself to see if I can duplicate these errors that you are getting.
