Available Layers: GUI
I’m using RHINO 8 and a display that has a resolution of 3840 x 2160. When I use the “Change Layer” command I see that the bottom portion of the GUI gets cut off while the top of the GUI goes all the way to the top of RHINO GUI in Windows 11. I’m still able to chose what layer I want and close the Layers but it’s really guess work which button it is to close the GUI.
Hello - I see this, with a lot of layers,thanks for the report. If you can ‘grab’ enoiugh of the top or bottom margins to move the dialog it will resize and show all the controls - after which it should just stay how you leave it.
RH-79958 ChangeLayer too tall
You can’t grab either the top or the bottom but what I found out is if you grab a side, I did the right side, then the GUI changes where you can grab the top and slide it down, then you can slide the whole GUI down and position it where you want.
Hey @CreativeType,
Can you run Rhino’s SystemInfo command and post the results?
– Dale
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Evaluation, build 2024-01-09
License details: Stand-Alone
Expires on: 2024-04-17
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
.NET 7.0.15
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4500 (NVidia) Memory: 19GB, Driver date: 12-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.15
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-26-2023
Driver Version: 31.0.15.3815
Z-Buffer depth: 24 bits
Total Video Memory: 19190 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
