I’ve downloaded the auxpecker 2.0 plugin and it is loaded in rhino however there aren’t any materials. I can see that there are some .auxzip files that I downloaded that say confetti material and another that says clay so I am assuming that those are the materials but how do I get them to load into rhino?
Also, I really don’t know how the plugin works. The help information is in spanish.
Do you have an auxpecker toolbar open? If yes, click on the black sphere with LMB.
A new window is opened, click with RMB on MaterialsRT. select import material/folder and navigate to the folder where the materials are stored. In my case I used C:\Program Files\Auxpecker Studio\MaterialsRT.
Alternatively you can create folder for each type of materials.
There are 6 types of materials (Auxpecker default map, auxpecker1Map, clay, ConfettiMaterial, ConfettiMaterial), so you need to repeat this step 6×.
Does Auxpecker have it’s own display mode? If not which display mode are you supposed to use? I really have no idea how to use this plug-in. Any help would be great.
Hi, thanks Vanessa for the email. I registered to download it but the download stalls everytime and never finishes. I managed to download it from a Chinese website. I believe it was a blog post that included the direct links from auxpecker’s website.
