Autosave NOT WORKING
Sorry,
but I’m quite (to say the least) IRRITATED with this.
I need to COMPLAIN.
You need to fix the AUTOSAVE function in Rhino so it works FLAWLESSLY.
I just lost three hours of hard work and I do not want this to happen again. I’m pretty sure that you do not want your happy users to experience this.
Ok - Enough of the frustration.
(Yes I’m using the BETA (for your benefit), but Rhino 8 works exactly the same way and I’ve experienced this so many times.)
I saved my project at 16:53 yesterday. When I left the office at around 18:30 I forgot to save. I returned this morning at 08:20 and continued to work. At around 9:05 the Rhino Beta crashed.
So I checked my special Rhino Autosave folder. I see in that folder that the last Autosave Rhino did was at 15:38 yesterday. After that no more Autosaves. Why?
My settings are to save every 20 mins.
Why did not Rhino save the file between 16:53 and 09:05 this morning ? THAT IS A SERIOUS BUG.
(And yes - I’ve checked the Windows Trash/Deleted Files, there are no hidden Autosave files there.)
This is not a viable way forward. And the Autosave is fraught with other bad decisions as well.
Let me list them:
  • Autosave should not depend on only a duration between saves, should also check how many commands the user has performed, so every 20 mins or every 10 commands, let the user set those values
  • Autosave should (try to) run when the user is NOT WORKING = idle time
  • It should NOT run when the user returns to Rhino to enter the first command after a pause, that is SUPER ANNOYING, with big files it can take 30 secs of unnecessary waiting
  • The autosaved files should not be moved to the Trash automatically (if ever)
  • The Dialogue that informs the user upon startup that Rhino saved an autosave file should be more elaborate on when it was saved and what was saved so that the user understand what he/she says yes to in the dialogue
  • You need to sort out having several Rhinos open at the same time and having crash issues and autosaves - I’m quite sure Rhino mixes up those things when it starts again, this might also somehow affect Autosave stopping saving
I think this should be a TOP PRIORITY to fix. Your users has been complaining about this for years and years. And it still it does not work.
McNeel PLEASE PLEASE fix this.
/Erik
And here is the SystemInfo. (And the Autosave should work disregarding what plugins are running. It’s problems has nothing to do with non McNeel plugins.)
Rhino 9 SR0 2026-9-1 (Rhino 9 BETA, 9.0.26244.12303, Git hash:master @ 5007fbd7b46c04cee8e766232af7a8896598fb4e)
License type: Commercial, build 2026-09-01
License details: Cloud Zoo
Expires on: 2026-10-16
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 95GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 7-22-2026 (M-D-Y). DirectX(11)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) Graphics (Intel) Memory: 2GB, Driver date: 10-11-2024 (M-D-Y).
- There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\Erik\AppData\Roaming\McNeel\Rhinoceros\9.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26244.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Also quite important:
If the program is set to save every 20 mins - it needs to actually do it (save the file) even it there was no activity on the part of the user. Or at least update the timestamp of the Autosave file. Otherwise they user has no clue as to weather the Autosave file is current or not …
Very important.
I am not disagreeing with you at all - in fact I agree with all of your suggestions.
Just for context:
Autosave, while it DID save my ass countless times, has been erratic and hit&miss since I use Rhino (which is since V4).
So while I wish those points will be addressed, I will not hold my breath.
Did you copy the path and open that folder via explorer? clicking the … doesn’t show the files.
The recycle Bin should have all the previous autosaves.
Of course I visited the Autosave folder. Looking even for hidden files.
And I scoured the trash can. And searched all three harddisks for possible autosaves.
But to avail. No Autosave files in the universe of my computer.
It is very relevant that Rhino updates the Autosave file even if the user is not doing anything for a long time. It might be, in my case, that there was no Autosave file due to inactiviy (I do not think so, but I’m not 100% sure). But as works today, it should have saved the file when I returned to the computer. And there was no file. So either the 20 min timer somehow stopped working, or the function that saves specifically when the user returns (to irritate the user) failed.
But just image, someone leaving the computer after 2 hours of heavy work (let’s say at 16:00-18:00) … And coming back 18 hours later at 12:00 noon. And no autosaves have been done since leaving the computer … How should the user know if the last autosave available was just before the end of the heavy work, or at some other point in time? Therefore it is important that the timestamp is continuously updated even if nothing is happening. Then the user would know that at 11:50 (just before the user returned) there was a good autosave and all work from the previous day was saved. In my case the last autosave was maybe 1 1/2 hour before I left (but I’m not sure). If the autosaving would have continued past me leaving and through the night, then I would know that all was fine and saved.
Did you? My Recylce bin is chockablock with autosave files.
I’m looking into this.
At first glance there have been no major changes from 8 to 9 in regards to autosave.
  1. Unattended/batch runs skip autosave crash recovery (Aug 2026, part of the RH-97819) Startup in an unattended run now suppresses the “Rhino did not close normally”
    recovery prompt entirely
  2. Mac: save compression re-enabled except for autosave
Doing some testing as well.
Testing went well, everything worked as expected.
  For Autosave to kick in, all of these need to be true:
  | Condition | Notes |
  | Autosave is turned on | Options > Files > Autosave, on by default |
  | A save interval is set | "Save every" minutes, default is 20 |
  | The model has unsaved changes | The countdown starts when you change something, not when Rhino opens |
  | Rhino is idle when the time is up | If a command is running or the mouse button is down, Rhino waits and autosaves right after the current command finishes |
  | Your license allows saving | An expired evaluation can't autosave |
  A couple of extras: the Autosave command saves on the spot, and any command you add to the "Always autosave before the following commands" list (same Options page) triggers a save before it runs, no matter the timer.
Hm,
how do you mean Japhy? “All went well?”
“It did not really go well for me.” … (Famous saying)
Problem 1:
Would it be a good idea to update the timestamp of the Autosave file (every 20 mins (or whatever the user has set) even if there has been no activity? This way the user will know that the Autosave file is recent and not old and stale? For example: User works hard for one hour. He leaves the computer for 24 hours and comes back. Windows restarted itself after 23 hours. Does he know that the Autosave file has really saved all the work he did? If the last Autosave file is +/- 24 hours old he will not be sure. If it is 1 hour old, he will be 100% sure.
I think that would save a lot of troubles and worries.
Problem 2:
Why does the Autosave frequently run exactly when the user returns to Rhino after a break? It is very very annoying.
Problem 3
Count command executions as well. In twenty minutes a lot can happen. Have a counter for how many commands the user thinks starts to count as “a lot of work”. Autosave after that as well. Either/Or.
Imagine doing some really complex stuff - can take just five minutes … and then it’s gone forever.
Problem 4
Why do the Autosave files disappear from the Autosave folder and end up in the Trash even if the program actually crashed. It’s fine that they end up there, but only when the Rhino was terminated in an orderly manner.
Thanks Japhy
/Erik
I have plenty of Autosave files in my trash as well. Hundreds of them.
My only problem is that the relevant ones never end up there, neither in the designated Autosave folder.
(That’s was overstating a bit - I quite frequently manage to save lost work using the autosave. It is not useless, it’s just not working every time, which is a pity.)
Just another small remark:
The best Autosave functions that other software have implemented save work continuously. It does not mean necessarily that you have to save the whole file after each command.
An alternative method is to save whatever stuff the user is doing (what selection, what command etc) in a small file on the side.
Then if the program crashes, the work can be reconstructed by running those commands consecutively from the last “full save”.
This way nothing relevant (not even the last command) is lost.
I run several design products using this approach. Works like a charm. When you restart the software you just start continue working where you stopped.
I think Rhino v. 10 should do that as well. Then your users will sleep well.
:wink:
/Erik
Good morning,
just to continue this odysse:
Now Rhino crashed again. Exactly at 10:00. I tried to print something from Rhino. It died.
Checking the Autosave files. The last file in the Autosave directory is from 09:30. That 30 mins … Not 20 mins. And this time i’m 100% sure that I was working in Rhino. Last things was working on the Layout.
And there is no Autosave file in the Trash.
So the last Autosave file is from the same moment I saved a new version of the work file. After that absolutely nothing.
So again … work lost.
Clearly something is not working.
Is it possible to watch the Autosave “timer” somehow? So I can help you pinpoint what is going on?
/Erik
Now this came up.
I now know that it is going to open the last autosave file in the Autosave directory.
But the dialogue needs to inform the user what file it is opening and at what point it was saved.
Also, an additional complexity: What if the user has several files/Rhinos open when the crash happens? Or the computer crashes with several Rhinos open?
What will happen when the user opens one Rhino? Will it manage to reopen several autosave files? (I normally have many Rhino instances open at the same time.)
(As a parenthesis - if the user has customized Rhino during the last session(s) … are these customizations lost as well? And also, if customizations are made in several running instances of Rhino, which instance customizations will prevail? Or will all of them be saved? (I know they will not…) )
/Erik
I have to chime in here and second a lot of the frustrations Erik is expressing. The auto purging of the autosaves from the app based autosave folder to the system based trash folder in so un necessary. The vast majority of OS’s retain your trash until you actively delete the files and so there is no space savings by putting them into the trash and then to access them you have to first restore them, navigate back to the autosave file and open it there. Seems needless, and from extensive experience, frustrating.
If Rhino is actively moving the file (I don’t presume to understand how that works) I assume McNeel is controlling that. If that is the case, it would be nice to have the following options:
  • Retain X autosaves, per file
  • Retain all autosaves for X amount of time, per file
  • Retain all autosaves in the Rhino autosave folder
  • Retain only the last X autosaves in the autosaves folder (move older autosaves to the system trash folder)
I would also like to second Erik’s suggestion that the Recovery dialogue provide the file name that it suggests it recovers. Often I will have two or more files open over night and Windows will decided that despite doing everything in my power it haaasssss to update. Then I have 2-4 files that failed to close properly, I have no idea which one rhino is trying to open, AND Rhino will only try to recover one of the files. The others are languishing in the system trash folder.
I’ve added a number of feature requests for these..
RH-98579 AutoSave: Recovery prompt should name the file and its save time
RH-98581 AutoSave: Incremental command-journal recovery between full saves
RH-98580 AutoSave: Recover autosaves from all crashed instances, not just one
RH-98577 AutoSave: Save during idle time and keep the autosave file current
RH-98576 AutoSave: Trigger by command count in addition to the timer
RH-98578 AutoSave: User options for retaining autosave files
Wonderful!
I’m so much looking forward to this being implemented. It will save som many lost hours and so much frustration.
Thanks
/Erik
I don’t use rhino WIP. Just Rhino 8. Me and my employees all experience the same issues with auto save, it’s really hit and miss. I hear cheering in the office when someone finds that their rhino actually autosaved after they have had a crash.
