somehow like this section.
Did it help?
I assume âBezierâ means single span and âNURBSâ means multiple spans. Any Bezier curve has an exact equivalent single span NURBS curve.
Aftermarket part or OEM part?
Choice of material for OEM parts depends on multiple factors including performance requirements, appearance requirements, volume (number of parts to be built), ability to match other surfaces if required, manufacturing capabilities and cost. Frequently tradeoffs are needed to reconcile conflicting requirements.
I know this, and you know that I know this. At least if we speak about a mathematical level. On a computational level this is not true. Some applications differentiate between these, since a pure non-rational Bezier geometry doesnât contain any information of Weights, Knots and conditional branches to deal with multispan data. Thus they are âlighterâ on a computational level. Algorithms can be much simpler when excluding certain properties.
Ideally a clean multispan skin might result in a clean and equally surfaced skin. But this is the ideal world. In practice people using multispan data, creating heavier geometry. Some exceptions are e.g. spheres and circles. But any rational geometry is much harder to further work with⌠Try _flowAlongSrf on a rational and a non-rational surface for example and see how this affects the cp count of the morphed geometry.
As I said, I donât want to start a discussion about it. As I said not all reasons and concerns are valid points if you ask me. But if we speak about (german) oem parts, the computational representation is Beziers (or single span Nurbs as a subset). At least for all the models I have worked at/with.
I believe the reason why certain single-span-only tools are still not part of Rhino, is the fact that any command needs to satisfy the multispan solution. For some functionality this becomes really difficult. Think about surface extrapolation or surface splitting (untrimmed). These are so important for daily modelling, doing similar things in Rhino is always a difficulty to workaround. Implementing these for multispan is much more demanding and so we see no true equivalent yet.
