Automatically Mirrored wall_Add Wall (profile)
Could anyone give thought to me to solve this issue?
Issue:
I wanted to create a wall which has Staggered Quad Panels.
For some reason, the edge parts of panel automatically mirrored as below image.
I don’t know the logic behind and the solution.
Here is revit file (2020) and RIR (Rhino 7):
FLIP PANEL_WALL PROFILE.gh (27.4 KB) FLIP PANEL_WALL PROFILE.rvt (5.3 MB)
Thanks for your help in advance!
@sungbok.song This actually seems to be a Revit bug. RIR creates the walls from the profile using DB.Wall.Create and it is Revit that seems to be deciding the direction of the wall. You can create the walls from the lower curve of the 4 panel curves Add Wall (Curve) and set the height on the wall but that needs a little more fiddling with the curves in your GH definition
Hi.
Thanks.
I was thinking to make separated walls as you mentioned.
At least I know it is Revit issue.
Thanks a lot.
