Hi
I’m trying to create the creases in the mesh automatically using a curve as a guide. But creases are created randomly. What might be missing?
The test Rhino file is attached
import scriptcontext as sc
import Rhino
from System.Drawing import Bitmap
import System
from System.Collections.Generic import *
import Rhino.Geometry as rg
from System import Array
import System.Guid
mesh01 = rs.GetObject("Select mesh", rs.filter.mesh)
mesha = rs.coercemesh(mesh01)
crv = rs.coercecurve(rs.GetObject("Select curve", rs.filter.curve))
pts = rs.MeshVertices(mesh01)
map = rs.MeshFaceVertices(mesh01)
pts_crv = rs.DivideCurve(crv, 100, False, True)
caps = []
for i in range(0, len(pts_crv)):
for j in range(0, len(pts)):
if rs.Distance(pts_crv[i], pts[j]) < 0.2:
caps.append(j)
cap = list(set(caps))
pythonIntegers = cap
dotNetIntegers = Array[int](pythonIntegers)
mesh = Rhino.Geometry.Mesh()
for v in range(0, len(pts)): mesh.Vertices.Add(pts[v])
for m in range(0, len(map)): mesh.Faces.AddFace(map[m][0], map[m][1], map[m][2], map[m][3])
mesh.UnweldVertices(dotNetIntegers, False)
mesh.Normals.ComputeNormals()
mesh.FaceNormals.ComputeFaceNormals()
mesh.Compact()
sc.doc.Objects.AddMesh(mesh)
rs.HideObject(mesh01)
sc.doc.Views.Redraw()
brecha.3dm (76.8 KB)
crease_test.py (1.1 KB)
