Hi David, I would like to automatically connect component output with other component’s input after the output param is correctly created in the SolveInstance. I have tried to add something like RecievedComponent.Params.Input[0].AddSource(this.Params.Output[0])
into AfterSolveInstance method, but I have problem with “An object expired during a solution” exception. I didn’t expect that AfterSolveInstance is still related to component/parameter expiration, if I understand correctly that nested/double calling of expiration cast this problem.
Thank you for any help.
Lukas
Update:
I have overridden the ExpireSolution
method and added ClearData
, ExpireDownStreamObjects
methods inside this method. Instead of ExpireSolution
method (usually used inside overridden method) I am calling CollectData
, ComputeData
methods and OnSolutionExpired
event sender. Automatic link (showed above) is added at the end of the overridden method.
It seems that this solution works, or at least I didn’t find any problems so far .
I will be happy for any comments or suggestions how to improve this solution. Thanks!
Update:
No, there is a problem to open saved component from the gh file . From
ComputeData
method I am receiving System.ArgumentException: ‘Component is not associated with a document’ - Component failed to deserialize itself.
Yes, you are not allowed to expire objects during a solution. Solutions are not per-component, they are for the entire document. Ideally what you do is make changes from schedule callback delegates.
You schedule a new solution from within the current solution, provide a callback method and then in that callback (which happens just before the next solution) you are allowed to add objects, delete objects, change data, modify wires, etc. etc.
GH_Document doc = ...;
doc.ScheduleSolution(10, ScheduleCallback);
private void ScheduleCallback(GH_Document doc)
// Make changes here, but *do not* start a new solution.
// Only expire objects, a new solution will start soon automatically.
Please do not override ComputeData or CollectData or ExpireDownstreamObjects unless you absolutely have to. Messing with the core default behaviour will have all manner of unpredictable side-effects.
Thank you, I have add doc.ScheduleSolution(...)
[delegate] into AfterSolveInstance
method and add to CallBack method constrain if == GH_ProgressStep.PostProcess
to run it only ones at the end, when the solution is finally solved. I added this constrain, becouse I found that CallBack methods is called more times; when disabled element is again enabled (even four times).
I found the problem. If more components are selected and I will disabled them through middle click menu, my CallBack function works only for one of them. If I repeat the procedure, the next component is solved. I am not clicking on any of them.
Do you know what can cast this behavior and how to solve it?
I have been thinking to move delegate from AfterSolveInstance
to ExpireSolution
after calling base method, but I am not sure, if it is a clear solution.
Thank you.
