Automatic measurement with Measure Length Macro
I have a lot of panels. Panels are similar but not same. And I have length measure macro button.
I want to make length measure automatically. Do it posible ?
sible?
Hi!
Can someone help me ?
Please give me a suggestion.
There is a dimension component in Grasshopper and you would have to input the points at the end of the edges.
Without knowing what your data looks like it is hard to guess how you could do this but I am sure it is possible.
First look up the Linear Dimension component from Display >> Dimension tab and understand what inputs it needs. Then work out how to get those inputs from your geometry.
Search for examples using Linear Dimension components
If you are still stuck, post a file with your geometry so people can help
Like this?
lenght.gh (15.5 KB)
Thank you so much !
