Rhino v4
Is there a way to configure Rhino v4 to automatically switch to a specified layer whenever using the various Dimensioning commands and then switch back to the previous layer after the Dimension command is completed?
Thanks
Rhino v4
Thanks
Assuming you always dims on a consistently named layer, you could change the macros on the dimensioning buttons (or make your own) to put the just-made dimension on the dim layer: e.g.:
! _Dim _Pause _Pause _Pause _SelNone _SelLast _-ChangeLayer "My dimension layer" _SelNone
PERFECT!!! Thanks
How could I add a Dimension Style change to this button macro? My Dimension Styles are named 1mm Height, 2mm Height, 5mm Height, etc.
