How can I do to run flowalongsurface automatically.
The base and target surfaces are known.
I need in Python
@cristiano.pasini here a quick try at translation
import Rhino
import scriptcontext as sc
def flowAlongSrf():
rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select object to sporph", False, Rhino.DocObjects.ObjectType.AnyObject)
go0 = Rhino.Input.Custom.GetObject()
go0.SetCommandPrompt("Source surface")
go0.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
go0.SubObjectSelect = False
go0.EnablePreSelect(False, True)
go0.DeselectAllBeforePostSelect = False
go0.Get()
if (go0.CommandResult() != Rhino.Commands.Result.Success):
return go0.CommandResult()
srf0_ref = go0.Object(0)
go1 = Rhino.Input.Custom.GetObject()
go1.SetCommandPrompt("Targe surface");
go1.GeometryFilter = Rhino.DocObjects.ObjectType.Surface;
go1.SubObjectSelect = False
go1.EnablePreSelect(False, True)
go1.DeselectAllBeforePostSelect = False
go1.Get()
if (go1.CommandResult() != Rhino.Commands.Result.Success):
return go1.CommandResult()
srf1_ref = go1.Object(0)
morph = Rhino.Geometry.Morphs.SporphSpaceMorph(srf0_ref.Surface(), srf1_ref.Surface());
geom = objref.Geometry().Duplicate()
if (morph.Morph(geom)):
sc.doc.Objects.Add(geom)
sc.doc.Views.Redraw()
return Rhino.Commands.Result.Success
flowAlongSrf()
@Gijs runs Ok… Perfect… but how do i pass the Id object to this example of yours.
My surfaces were created by rhinoscript.
@cristiano.pasini that’s even more simple. In that case you don’t need the whole Rhino Getobject stuff. Just make srf0_ref equal to your source and srf1_ref equal to your target.
Rhino.Geometry.Morphs.SporphSpaceMorph needs <Rhino.Geometry.BrepFace>
How to extract Geometry Brep Face from Id. How to convert?
Maybe this helps? Otherwise post your code
import Rhino
def flowAlongSrf():
srf1 = rs.GetObject("select source surface")
srf2 = rs.GetObject("select target surface")
srf1 = rs.coercesurface(srf1)
srf2 = rs.coercesurface(srf2)
morph = Rhino.Geometry.Morphs.SporphSpaceMorph(srf1,srf2)
flowAlongSrf()
Can I morph mesh grips object?
Hi. Sorry for bumping an old thread but I’m wondering if I want to access the flowed object what would be its ID? I tried selecting it by using ‘LastCreatedObjects’ for example but it does not seem to work.
If I would want to name the object when flowing it, how would I do it?
Thanks.
You need to work with Rhinocommon.
First convert the object:
rs.coercesurface(ID)
Then work with Rhinocommon…
Rhino.Geometry.Morphs.SporphSpaceMorph is Rhinocommon
