Automate slider or gene pool
Hello to all
I need to automate an slider or a gene pool,
similar as Galapagos does it or others plugins.
where should I start?
thanks in advance
Carlos.
What programming language are you working in?
C# - Visual Studio
thanks
Do you want to create a UI for this as well, or is it just a bit of code that gets triggered, runs and then silently completes?
UI as well.
thanks
Will take me a while to come up with an example.
See attached cs class. Hope it can get you started.
Gripoff.cs (4.7 KB)
My test file for this:
solvertest.gh (16.2 KB)
Very useful for getting started. Thanks2
// Rolf
thank you very much!
yes for shure!.
You might also want to check out FrOG (Framework for Optimization in Grasshopper), on GitHub:
It’s an open-source optimization tool for Grasshopper, and works with sliders and genepools.
Grasshopper_InOut has all the code related to that.
thank you, @ParamDesSing
I will have a look.
best
carlos.
