AutoEntourage Transparency with each load
I am using AutoEntourage to create randomized collages and then use an automated SaveToViewport function to save the image. I’m running into a problem where I manually have to turn on Alpha Channel every Load to get my backgrounds to be transparent in the viewport. Does anyone know of a default setting in Rhino that can set all materials to have the Alpha Channel turned on for every fresh AutoEntourage Load?
Thanks in advance
Perhaps @v-machine can help you out here…
