AutoCPlane does not work on selected planar edges. It is necessary to DupEdge to get a curve, unselect the curve and reselect it in order to get it to work.
Good catch! I logged it here.
@Helvetosaur is that a new manifold for your Ford?
No, it’s a heater duct splitter for the 914. Stock, the heater blower only had one hose going to the heat exchanger on the driver’s side. The passenger side heat exchanger also has an inlet, but is capped off. At the time, some dealers added the passenger side hose using some VW parts including a splitter. Thought I would do the same. The splitter part is unobtanium now, so I’m going to 3D print one. The part is designed to print without support material. Probably need to make a few tests until I have what I like.
I know that I should come to your workshop!
RH-84890 is fixed in Rhino 8 Service Release 15
