Autocompletion failure
autocompletion at the command prompt is a great feature.
But it needs to be consistent. Otherwise it is an irritating failure.
Like PushPull and Purge.
Well, when you start Rhino “PU” completes to Purge (which I hope is a very seldom used command for most users).
After a while using PushPull autocompletion “PU” switches to PushPull. Great.
Next time you start Rhino the same thing happens again. So when I’m expecting PushPull when typing “PU”, I get the Purge dialogue. Nuisance.
PLEASE - make it consistent and permanent. Let the user decide what PU should complete to. Not an algorithm over and over again. It is a failure.
Rhino should learn/save what the user wants autocompletion to do. Not force Purge on PushPull user.
Thanks
/Erik
this may be worth creating an alias for. In v9 you have direct aliases that do not require an enter key
for instance for push pull, you may set pp as the alias. ( I use this one myself)
for purge,I’d suggest something like pg or other key combo that makes sense to you.
