AutoCAD hard crash when opening write-protected files
Hello friends, my team has been experiencing a guaranteed hard crash when opening read-only files (ones that are currently opened by someone else on the network). This issue has not always existed but it would be difficult for me to say which version initially introduced it. I just updated to 1.2.29 and the crash still occurs. Here is a screenshot of the displayed error message when crashing:
I couldn’t repeat here in a simple example (file is opened in 2024, 2025 opened it read only)
We’ll need more info about your environment; the About info, if this only happens on a networked filed, any variables you can think of. Thanks!
We are using AutoCAD 2026 on Windows 11, and yes this issue is for network files. All of our PCs have different specs as far as I know so it would be hard to say that it’s a hardware issue. I could send the AutoCAD error report dump file if it might have useful info (I don’t know if these files contain sensitive data).
Yes the dumps can be useful, you can always PM them if you are concerned about the data
Just so I get the correct picture:
User A has the file open non read only and the file is on a shared network drive.
User B then tries to open the file read only and it crashes immediately on start up?
I’ve messaged you the files, and yes that is correct. When the file is opened by User B, it shows the typical message that the file is already opened by User A on PC A etc, and asks if you want to open the file read-only. The file attempts to load but another dialog appears saying “file is write protected”, before crashing. What I noticed after uninstalling RiA is that this second message does not appear, and the file loads as normal without crashing.
Thanks let me do some investigation and get back to you!
Hi Mika,
I have still not been able to reproduce the crash, however there was enough in the files you sent to pin point that the crash was caused by RiA and where, I have modified the way we are handling AutoCAD documents which should address the issue. The fix has been pushed in V1.2.30, are you able to download it an try it and see if it does resolve the issue? do let us know either way!
Thanks
Tom
It works! You’re a legend, thanks so much again.
