Auto-viewcapture all views to JPEG file
Hi all,
I have done a script to export all views to JPEG file.
It works in Rhino5, but for some reason it doesn’t work in Rhino6…
Does anyone know why?
Thanks for any suggestion,
Auto_Print_All_Views.py (811 Bytes)
try this (raw string):
path = r"D:\image\{n}.jpg".format(n=n)
or this (escape the ‘\’):
path = "D:\\image\\{n}.jpg".format(n=n)
I see… for the format I should not use string to assign, thanks axa,
I found that there is a bug in my script…some views has been overwrited…which means, the image it saves is not exactly the view with the same name I saved in Rhino…I have no idea why, it is fine if I have just 4 or 5 views saved in Rhino. But it went wrong when I have a lots of views… :sweat:
I guess it could be something wrong with the for loop.
Auto_Print_All_Views.py (820 Bytes)
