Hi (@Brian I guess)
In replies I find myself linking to the online helpfiles quite a lot.
As Discourse has the feature of auto suggesting @username links, I was wondering how hard it would be to create a customized database and linksystem for linking to command helpfiles.
I wonder if a special format would be needed or maybe it is possible to auto-recognize and suggest linkage; typing a known commandname would pop-up the suggestion of linkage to the helpfile to easily create replies like so:
Try and Join the surfaces first. Then try and run Contour with the spacing you want.
Next you can CurveBoolean the sections to create…
I often type the command with underscore for international compatibility (like so _OffsetMesh) maybe that could be a formatting to trigger auto-suggestion.
my 2c
-Willem
