Even though the gumball sticks to it when I ctl/shift, something as simple as drawing a 2 point rectangle draws completely past the object.
“…aligns with the selected curve, surface, or sub-surface…”
I guess AutoAlignCPlane is not interacting with meshes / mesh faces.
EDIT:
my first gues was wrong
it works here Rhino WIP, on a simple _meshBox
refering to this topic
it should also work with mesh faces.
@Joshua_Kennedy
Hi Dale -
If you could export the mesh that misbehaves, I will add that to RH-78462 CPlane: AutoAlign: Ngon failure sample
Mesh ngons needed handled specially. I put in a fix for it yesterday and it should be resolved in SR 2.
Thank you guys.
