Auto CPlane does not seem to work with mesh edges or faces
Am I doing something wrong or does the Auto CPlane option currently ignore meshes?
PS: It might be that my ngon mesh faces aren’t 100 % planar …
Could it be improved so Auto CPlane snaps to meshes, faces and their edges when selected with Control+Shift+LMB?
The AutoCPlane aligns to mesh faces but not mesh edges. Mesh edges are line curves which you can’t really make a sensible plane from.
Can I get an example of what the AutoCPlane isn’t aligning to and what you expect the alignment to be?
Interesting. I can select a mesh edge and use the command CPlane, Object and I get a CPlane aligned to the edge with its X-axis.
The file contains a surface, a mesh with two maybe problematic quad faces and a mesh with a single triangular face. And a line…
Auto CPlane only works with the surface. It would be interesting to get a perp frame on a line, even on a curve this would be really useful…
auto_cplane_problems.3dm (60.6 KB)
Im having the same issues…
Hi Martin -
That seems to work fine with the triangular face in the current version here.
It looks like there is some issue with that specific mesh, yes. I wasn’t able to reproduce this with a Ngon mesh that I created myself but I’ve put this failure case on the list as RH-78462 CPlane: AutoAlign: Ngon failure sample
RH-78462 is fixed in Rhino 8 Service Release 2 Release Candidate
