I think I understand how to use the Auto CPlane and it seems it does not orient itself to blocks.
It would be great if it did. Auto CPlane to block plane please
Another really usefull option would be Auto CPlane to GumballâŚ
Do you in this case mean the âtransformed planeâ of the block instance?
Iâm having a hard time understanding the use of that, can you elaborate?
For the block Iâd expect the CPlane to snap to the transformed plane, yes.
Letâs say I wanted a CPlane offset and tilted, not directly on a face of a polysurface. I can copy and drag a face and re-orient it to my needs, then deselect and select again so it is my new Auto Cplane (Object).
Now if the Auto CPlane snapped to the Gumball, I wouldnât need to use a surface or curve or anything to have a selection for the Auto CPlane to have an input.
I have a macro to set the CPlane to Gumball so I know how to set a CPlane to whatever origin and orientation I need but I thought it could be part of the new Auto CPlane functionality.
Auto CPlane doesât work for Mesh or SubD faces⌠Would be great if it did. However, instead of adding all object types as options in the Auto CPlane settings, letâs imagine Auto CPlane could snap to the Gumball. Instead of choosing between Align to Object / World / View in the Auto CPlane settings, F4 could be used to toggle the gumball orientation and after a small pause, the CPlane snaps to the Gumball.
Command: CPlane
CPlane origin <0.000,0.000,0.000> ( All=No Curve Elevation Gumball Object Rotate Surface Through View World 3Point Undo Redo ): gu
Command: _GumballAlignment
Gumball alignment ( CPlane Object World View Cycle ): _Cycle
Command: CPlane
CPlane origin <-66.808,372.224,354.937> ( All=No Curve Elevation Gumball Object Rotate Surface Through View World 3Point Undo Redo ): g
Command: CPW
Command: _CPlane
CPlane origin <-66.808,293.014,177.657> ( All=No Curve Elevation Gumball Object Rotate Surface Through View World 3Point Undo Redo ): _World
Choose world CPlane ( Back Bottom Front Left Right Top ): _Top
I think itâs reasonable that it would align to those objects. I opened and issue here.
As for tying it to the Auto CPlane to the gumball I think it on some level makes sense but I can imagine situations (they may or may not be real) where you may not want them to. It could potentially be another alignment mode for the Auto CPlane in addition to the ones that currently exist.
Iâd like to see that maybe as a test to see if it really makes sense
I second that wish, please make it work with the Block object faces the same as it works with the polysurface faces. While using VisualARQ all elements are blocks and Auto CPlane is useless in these conditions. Itâs a shame because itâs a good feature.
For example, a very common usecase would be to use Auto CPlane on VisualARQ Walls.
Hi Jakub -
RH-74183 CPlane AutoAlign: Works with blocks, mesh faces and SubD faces
â Apparently, this ticket was implemented in Rhino 8.0. Which version are you trying this on, and can you post an example that fails?
Hi, it boils down to that I canât select the face of the block.
Block Auto CPlane.3dm (84.8 KB)
Rhino 8 SR5 2024-2-27 (Rhino 8, 8.5.24058.13001, Git hash:master @ eaa901528453bac5a3cfc23321bdf4d767238d34)
License type: Commercial, build 2024-02-27
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.11
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 5-24-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 535.98
- Windows Main Display is laptopâs integrated screen or built-in port
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 5-24-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 535.98
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
- Secondary monitor is laptopâs integrated screen or built-in port
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-24-2023
Driver Version: 31.0.15.3598
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp âDatasmith Exporterâ 5.3.2.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp âVisualARQâ
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp âBellaâ 24.2.0.0
C:\Users\Czaja\Desktop\Rhino_7_Win_2023.0417\HDRLightStudioTexture.rhp âHDRLightStudioTextureâ
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp âTibidaboâ
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp âCrayonâ 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\VisualARQLABS\1.4.0\VisualARQLABS.rhp âVisualARQLABSâ 1.4.8571.26036
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp âCommandsâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp âLegacy Rhino Renderâ
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp âMeshCommandsâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp âIronPythonâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp âGrasshopperâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp âRhinoCodePluginâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp âBlockEditâ 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp âSectionToolsâ
Hoovering mouse cursor over the polysurface (white object) and holding ctrl + shift highlights polysurface face which after clicking becomes a âbaseâ for the CPlane
Hoovering mouse cursor over the block (red object) and holding ctrl + shift highlights highlights the whole object and setting up CPlane doesnât work
