Version: Version 8 (8.32.26160.13002, 2026-06-09)
Device: MacOS
When an Attribute User Text field is really long (say with a nested object data), you can no longer resize the key column:
I can try to resize the value column, but then when i go to resize the key column, it automatically forces the value column to take up the rest of the width, resulting in strange behavior:
at certain breakpoints this causes the value column to re-render endlessly when trying to add a new field, shrinking then resetting, albeit this is harder to reproduce.
