Attribute 'Intersect' of 'namespace#' object is read-only
Hi David, Pascal,
Here is that old script. :wink:
walden.py (4.4 KB)
It seems to work here, with the radii and angles you mentioned in the original discussion:
That is radii 10 and 11 and angles 30 and 25 degrees.
The script may fail with other values … don’t know :confused:.
Or the values may not have a geometric solution, in which case the script simply breaks, without any message … sorry.
What are the values that now make the script break ? :slight_smile:
Thanks, cheers.
EDIT:
Sorry, I see now that the values are 4, 5, 35, 45.
It still seems to work here :slight_smile:
… But the line passing throuh the circle center seems to be too short …
Anyway, here is the file:
walden-18-5-22.3dm (37.1 KB)
EDIT AGAIN:
I made the script draw a longer line.
Hope it helps … :slight_smile:
walden-b.py (4.4 KB)
