Attractor 'Spinning Tops'
Hi, I’m currently trying to create a definition that will allow me to set an attractor point from which the object’s rotation that are closest to it will be enhanced only clockwise.
Essentially just increasing the “Spin” the closer they are to said point, so far my results have only resolved in the objects rotation being affected in a jittery back and forth style as seen below
Ideally the effect created as the attractor moves along the curve, would be like spinning tops gaining momentum and then slowly decreasing the further away it goes.
Hopefully this makes sense and if anyone has any advice would be greatly appreciated,
Thanks
Spin Attractor.gh (16.9 KB)
File?
Sorry it’s now attached :slight_smile:
jcmv_design.gh (24.7 KB)
wow @Mahdiyar Beautifully done! Thanks so much for your help :wink:
