Attention Teachers- How can we help and support you to teach Rhino?
Next to all modeling commands. There are barley any tutorials and instructions about the UI. How to adjust it, how to take the settings from the school comptuer to the home device. In a simple way! For non computer-affine people.
Explain in an illustrated easy way the difference between .RUI, .RHC, .ini, .template (hatches, annotation, LineStyle, displaymodes)
A simple overview what is bound to a Document what is bound to the Programm.
This is the part of Rhino that gets super difficult for most Students even if they like Rhino.
that is awesome feedback, thanks!
Hi All,
As industrial designer and teacher, I usually have to explain how to model complex forms, so I started creating some videos for my students showing some workflows I suggest.
Most of the examples are typical cases that show a good process that are not evident for new rhino users.
https://www.youtube.com/@joacolaborda
Spanish audio but with subtitles in english
I changed all the icons that have a flyout to remove their RMB command.
This way, a right-click opens the toolbar instantly. I find this much faster.
please create a thread for these videos so they don;t get lost here.
when you make a new one simply add it to your thread-
thanks for making these!!
Well, everyone prefers their own way of command input. Personally, I find it more convenient and quick to have access to two alternative commands on a single icon, using a single mouse click. I don’t mind holding down a mouse button for a brief moment to get access to the extra icons it consists. :slight_smile:
please can we have this ?
Paragraphs with ID
… for nice urls / jump to paragraph
@KelvinC - are you the right person ? this should be a easy tweak if there is a nice template mechanism in the background.
the html of the help is not nice, there should be paragraph ids:
for example
https://docs.mcneel.com/rhino/8/help/en-us/commands/subd_symmetry_commands.htm
i want to be able to send a link to my customers or students, that describe / jump a certain command or option.
should allow
https://docs.mcneel.com/rhino/8/help/en-us/commands/subd_symmetry_commands.htm#reflect
see the id-marker at the end of the url:
#reflect
the helps html is missing id s for this
thanks for an update on this. - kind regards - tom
@Tom_P
I use command names as bookmarks. They are case sensitive. It will work if you use
https://docs.mcneel.com/rhino/8/help/en-us/commands/subd_symmetry_commands.htm#Reflect
Or you can use
https://docs.mcneel.com/rhino/8/help/en-us/commands/reflect.htm
(The command names must be in lowercase.)
You can also highlight any text in the topic, right-click, and select Copy link to highlight.
This example gives you
https://docs.mcneel.com/rhino/8/help/en-us/commands/subd_symmetry_commands.htm#:~:text=Two%2Ddirection%20reflection
Thanks
ok great - thanks for pointing out:
the jumpt to Paragraph / Fragment #Reflect must be first character uppercase.
the R is important. (my lazyness - i tried #reflect and gave up).
addressing the command reflect.htm
thanks.
kind regards - tom
I logged this request as
Thank you.
@Tom_P are you expecting to put all the fancy at the end of https://help.rhino3d.com/ to get to a specific command?
you means
....rhino/8/help/en-us/commands/subd_symmetry_commands.htm#:~:text=Two%2Ddirection%20reflection
no.
but if
help.mcneel.com/loft
will bring me to the command of the current version it would be fantastic.
i am not a web expert but some redirect in the htaccess should do it.
chat.gpt suggests…
RewriteEngine On
RewriteCond %{HTTP_HOST} ^help\.mcneel\.com$ [NC]
RewriteRule ^([a-z0-9\-]+)$ https://docs.mcneel.com/rhino/8/help/en-us/commands/$1.htm [R=301,L]
which will need some update for each new release…
Seems reasonable. I updated the YouTrack issue with these details.
